Bigger clutch?
https://slantsix.org/forum/viewtopic.php?t=43950
Author:  polkat [ Tue Mar 08, 2011 9:04 pm ]
Post subject:  Bigger clutch?
Is anyone yet making a bigger clutch for the slants that doesn't require a different bellhousing? I read somewhere on this board that a 10-1/2" can be used but it requires a different (custom?) bell.
________
Ipod games
Author:  Joshie225 [ Tue Mar 08, 2011 9:27 pm ]
Have you read this? http://www.slantsix.org/articles/clutch ... utches.htm
Aside from the scalloped 10" clutch nothing larger than the 9 1/4" is a direct bolt-in.
Author:  polkat [ Wed Mar 09, 2011 1:35 am ]
Thanks for that. Pretty good info.
I did notice that the article was written 10 years ago, but I guess nothing has changed since then?
________
MERCEDES-BENZ CL-CLASS
Author:  DusterIdiot [ Wed Mar 09, 2011 5:24 am ]
Post subject:  THe 3 slant clutch options...
Yep there are only 3 bolt in options at the moment...
Mopar A-body 3 and 4 speed cars with our standard flywheel
can use the 9 1/4" and 10" clutch...
Some slant six trucks use a larger flywheels when opted for the NP435 "granny geared" 4 speed...these use the same 11" clutch
that the 383-2v 3-spd vehicles used...the give away is the low mounted
starter...the problem with this installation is the need to use a hammer
to make room in the A-body for the bellhousing and secondly the NP 435
does not have the same bolt pattern as the other manual trannys...so
you then will need to have it modified or make an adaptor...
Author:  1974duster kev [ Thu Mar 10, 2011 5:05 pm ]
Spec is drillin my wheel for a 9 1/2 inch clutch.
Kev
