It is currently Sun Nov 15, 2026 12:01 pm
 Post subject: rebuild
PostPosted: Tue Mar 08, 2011 9:28 pm
ok do yall know if a 1967 doge 3 speed manual transmission kit will be usable with the inside of a 1965 dodge 3 speed manual transmissions. help! thanks.
PostPosted: Tue Mar 08, 2011 9:36 pm
Are these both A903 passenger car transmissions? If so at a minimum the '67 kit is going to lack the rear main shaft bearing. If one trans is an A903 and the other an A745 then I expect almost nothing to interchange.
