| Head interchange https://slantsix.org/forum/viewtopic.php?t=43962 |
| Author: | 82Stepside [ Wed Mar 09, 2011 5:32 pm ] |
| Post subject: | Head interchange |
Will a head off an 80's engine (hydraulic cam) work on an older block, say from '66? |
| Author: | Fopar [ Wed Mar 09, 2011 5:54 pm ] |
My best guess is if you change the rocker arms, yes. Richard |
| Author: | Joshie225 [ Wed Mar 09, 2011 5:58 pm ] |
Yes, it will work. You'll need to use the mechanical valve gear from the solid lifter engine, but with the rear-most hold down bolt from the late head. The '81+ valve cover will need to stay with the head. |
| Author: | 82Stepside [ Wed Mar 09, 2011 6:36 pm ] |
Would one be better than the other? |
| Author: | Joshie225 [ Wed Mar 09, 2011 6:59 pm ] |
The later heads have induction hardened exhaust valve seats which are more wear resistant. The '67 and newer heads have an improved combustion chamber. http://www.slantsix.org/articles/combus ... hamber.htm |
