| Engine I.D. help? https://slantsix.org/forum/viewtopic.php?t=43965 |
| Author: | drgonzo [ Wed Mar 09, 2011 7:16 pm ] |
| Post subject: | Engine I.D. help? |
MY 63 dart I purchased back in the fall has a blue engine, my research says it should be red. Here are the numbers stamped into the top of the block just below the No. 1 plug. RW225R 2995 118 Do these tell more than it's a 225? Date? |
| Author: | drgonzo [ Wed Mar 09, 2011 7:30 pm ] |
Ahh. the casting number indicates a '68-70 225. What do the other stamped numbers mean? |
| Author: | SlantSixDan [ Wed Mar 09, 2011 7:37 pm ] |
Interesting ID stamp. If the casting number on the manifold side of the block is 2806830 (with or without additional numbers appended after a dash), then the stamping decodes as follows: RW: Passenger car engine built at Windsor, Ontario 225: Cubic inch displacement R: Regular fuel 2995: Built on October 9, 1969 118: Engine daily serial number If your car's got an automatic transmission, you need to make sure there's a spacer between the torque converter nose and the crankshaft rear flange counterbore. The counterbore and nose grew larger together for the 1968 model year, and if a '68-up engine (w/large crank counterbore) is used in front of a '67-down automatic (w/small-nose torque converter) without the spacer, the trans front pump bushing and seal will die early and often and you can get vibration issues. |
| Author: | drgonzo [ Wed Mar 09, 2011 7:49 pm ] |
Thanks Dan. I will check out the torque converter situation. Would the space be custom or an aftermarket or OEM piece? |
| Author: | 61 V200 [ Wed Mar 09, 2011 8:13 pm ] |
Question: How does 2995 translate to Oct 9,1969? |
| Author: | SlantSixDan [ Wed Mar 09, 2011 8:40 pm ] |
Chrysler began using a 10,000-day calendar on 29 July 1961 (0001). You can find the portion of this 10-kiloday calendar at the front of most parts books. You can enter a 4-digit date code into a decoder such as this one to get the calendar date associated with the code. |
| Author: | Doc [ Thu Mar 10, 2011 10:52 am ] |
Quote: Thanks Dan. I will check out the torque converter situation. Would the space be custom or an aftermarket or OEM piece?
I have the adapter ring(s) if needed.DD |
| Author: | drgonzo [ Thu Mar 10, 2011 12:02 pm ] |
Thanks doc. Will I have to pullythe tranny to see or can I tell with the inspection cover off? |
| Author: | SlantSixDan [ Thu Mar 10, 2011 12:09 pm ] |
Unfortunately, because the spacer goes between the torque converter nose and the crankshaft counterbore, either the engine or the trans must be pulled to see if it's there. |
