It is currently Mon Nov 16, 2026 4:19 pm
 Post subject: 74 dodge dart oil pan?
PostPosted: Mon Mar 14, 2011 2:10 pm
Hey I have a 74 dodge dart 225 installed in my 56 dodge pick-up the oil pan has a pin hole in the side probably from all the New York salt over the years. Anyways I also have a 78 225 motor on an engine stand in the garage after looking at the 74 pan it is a center sump and the 78 is a rear sump will these pans interchange or should I just pull the pan and weld the pin hole? also is there any aftermarket or nos pans for the 74 Dart? Thanks and have a Great Day! Jim
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Mon Mar 14, 2011 2:40 pm
The '78 pan has to be a truck pan if it's rear sump. If you have room for it use it. You will also have to use the pickup tube for it too. :D
PostPosted: Mon Mar 14, 2011 2:46 pm
Thanks yeah room will not be a problem. Thanks again! is it the same gasket?
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 3 guests
