It is currently Sun Nov 15, 2026 7:52 pm
 Post subject: Bigger clutch?
PostPosted: Tue Mar 08, 2011 9:04 pm
Is anyone yet making a bigger clutch for the slants that doesn't require a different bellhousing? I read somewhere on this board that a 10-1/2" can be used but it requires a different (custom?) bell.
________
Ipod games
PostPosted: Tue Mar 08, 2011 9:27 pm
Have you read this? http://www.slantsix.org/articles/clutch ... utches.htm
Aside from the scalloped 10" clutch nothing larger than the 9 1/4" is a direct bolt-in.
PostPosted: Wed Mar 09, 2011 1:35 am
Thanks for that. Pretty good info.
I did notice that the article was written 10 years ago, but I guess nothing has changed since then?
________
MERCEDES-BENZ CL-CLASS
PostPosted: Wed Mar 09, 2011 5:24 am
Yep there are only 3 bolt in options at the moment...
Mopar A-body 3 and 4 speed cars with our standard flywheel
can use the 9 1/4" and 10" clutch...
Some slant six trucks use a larger flywheels when opted for the NP435 "granny geared" 4 speed...these use the same 11" clutch
that the 383-2v 3-spd vehicles used...the give away is the low mounted
starter...the problem with this installation is the need to use a hammer
to make room in the A-body for the bellhousing and secondly the NP 435
does not have the same bolt pattern as the other manual trannys...so
you then will need to have it modified or make an adaptor...
PostPosted: Thu Mar 10, 2011 5:05 pm
Spec is drillin my wheel for a 9 1/2 inch clutch.
Kev
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
