| 4-speed tranny https://slantsix.org/forum/viewtopic.php?t=4399 |
| Author: | Slantosis [ Tue Nov 05, 2002 11:07 pm ] |
| Post subject: | 4-speed tranny |
I was curious about how many of you have a 4 speed behind your slant? I'm asking because I want to eventually do the swap, so I'm wondering what all of you guys did out there? I have a 66 slant that I am putting in my 73 duster and I'm trying to gather parts for a future transplant. So far I think I need:
| Author: | Dart270 [ Wed Nov 06, 2002 6:16 am ] |
| Post subject: | hmmm |
If I read you right, you are trying to put a 4spd manual in your '73 with a '66 engine. It would be best to find a 4spd Slant6 donor car, or all the parts from one. If you get a '67-down, it will have the right flywheel, otherwise you'll need an adapter to fit the smaller centering ring on your crank hub. You need - bellhousing to fit transmission, A833 trans or A833 OD trans, shifter, pedal assy and clutch linkages, clutch (p. plate, throwout bearing, disc), flywheel to fit crank hub, floor hump to clear shifter. Any 4spd Dart/Valiant is good to find, or 4spd Volare/Diplomat/Aspen, either with a Slant6 since the Slant takes its own bellhousing. Lou |
| Author: | Slantosis [ Wed Nov 06, 2002 7:10 am ] |
Thanks Lou, what is the difference between an OD tranny and a non OD? Brett |
| Author: | Dart270 [ Wed Nov 06, 2002 7:30 am ] |
| Post subject: | different ratios |
They are essentially the same trans, but with different ratios. The regular 833 commonly had ratios of 3.09 or 2.66 (1st) through 1:1 (4th). The 833OD used 3.09 (1st), 1.67 (2nd), 1 (3rd) and 0.73 (4th). So the OD is just a wide-ratio 4spd, or you can think of it as a normal 3spd with an OD 4th gear. For economy, the OD is probably better, but it's not the best for performance/racing because the RPM drops between gears (esp 1st and 2nd) are so large. Lou |
| Author: | 87Slant_sickness [ Wed Nov 06, 2002 2:58 pm ] |
if you need i have a spare aluminum belhousing and manual clutch fork along with a 10" clutch pressure plate and bearing that i'd let go for almost nothing the clutch has less than 1500 easy going miles on it, but this is only if you go the OD route, i may have a aluminum OD tranny and shifter for sale if i can grab a good non-OD for my setup... Justin |
| Author: | Ontosdriver [ Wed Nov 06, 2002 3:17 pm ] |
| Post subject: | OD 4spds in vans |
Hey Gang After lurking for awhile I decided to finaly register and post something! I found my /6 OD4spd in a '79 Dodge van. Got the whole running thing real cheap too. Somthing to think about if your looking for the whole engine/trans thing. |
| Author: | Keith [ Fri Nov 08, 2002 4:55 am ] |
Slantosis, On the for sale part of this board "oldmopars" is wanting to change a four speed Duster to automatic. You might want to talk to him. He would have all the stuff you need. Good Luck! |
| Author: | dgc333 [ Thu Nov 14, 2002 10:58 am ] |
| Post subject: | Re: OD 4spds in vans |
Quote: Hey Gang
Just something to keep in mind! The Van and Pick-up A833OD tranny is over three inches longer than the A-body tranny which will require the drive shaft to be shortened. Also, the shifter mounting pads are in the wrong location for an A-body so some custom fabricating for the shifter mounting bracket is going to be required.After lurking for awhile I decided to finaly register and post something! I found my /6 OD4spd in a '79 Dodge van. Got the hole running thing real cheap too. Somthing to think about if your looking for the whole engine/trans thing. None of this is hard just something you need to be aware of. I used the A833OD from a D100 pick-up in my 68 Barracuda and Doc included all the items I had to deal with in his article on 4-speeds http://www.slantsix.org/articles/4-spee ... speed1.htm |
