HELP with Which Carb?
https://slantsix.org/forum/viewtopic.php?t=43990
Author:  zk6216 [ Fri Mar 11, 2011 12:04 pm ]
Post subject:  HELP with Which Carb?
Alrighty im looking for a carb for an 85' D100 custom with a Slant Six One BBL but i dunno if mine is CAL or FED.
the one on it now seems to be a 6145 but the guys that owned it before did not know what they were doing it has the mixture sol. but there seems to be no plug for it or the 02 sensor also was taken off but do not see a plug end to plug it into. How can i tell for sure?
thank you!
Z
Author:  carlherrnstein [ Fri Mar 11, 2011 1:06 pm ]
Are you in a location where there are emissions tests?
If not then you would be a lot better off with a holley 1920 or holley 1945 and a normal non-lean burn distributor.
Author:  zk6216 [ Sat Mar 12, 2011 7:52 am ]
Post subject:  hmmm
Just a visual and gas cap test, but should i put an o2 sensor back in the truck i do not even see a plug for the idle mixture solinoid anywhere? How will putting those on effect the ESA? or do they have that to?
Zak
