Shaker
https://slantsix.org/forum/viewtopic.php?t=43997
Author:  Brussell [ Sat Mar 12, 2011 2:35 am ]
Post subject:  Shaker
Hi,
Has anyone ever had a shaker hood scoop setup on their slant 6?
If you are unsure what I mean look at this link:
http://en.wikipedia.org/wiki/Shaker_scoop
I was possibly thinking about it and wasn't sure wether it would be worth it, thinking maybe a 10 - 15 hp gain?
build:
1.7 1.44 valves, 500cfm 4bbl carb, long runners, high compression (around 9.5:1 or 10:1), port and polish job, elec ignition + bigger coil, and headders with 2.5" exhaust.
Author:  63Dart170 [ Sat Mar 12, 2011 6:22 am ]
I'm no expert but I think any gains would be negligible.
I'm one for symmetry, so to me a shaker off to the side would look weird, but different is always good in my book - there's a few pics out there of slants with blowers sticking through the hood that look ok.
Author:  hantayo13 [ Sat Mar 12, 2011 7:09 am ]
would look kewel...might gain a few ponies @ over 80 mph or so
keep on roddin'
Author:  olafla [ Sat Mar 12, 2011 9:31 am ]
Bi Brussel.
The real high pressure buildup is along the windshield, so a rear-facing scoop or cowl induction would probably give more effect.
A low mounted hood scoop too far forward will in some cases end up in a local low-pressure zone. You can try to visualize the part of the air flowing up from the front of the car, making a curve starting at the edge of the hood, before straightening out, lowering some and then meeteing the windshield, where a pressure buildup happens. At the high point of that curve, the pressure under it is actually lower than above. A car built like a brick, with an edged or slightly lower hood front, will have a more pronounced effect, and placing the opening of the hood-scoop in that zone will not be a gain.
I know it may sound stupid, but make you own wind tunnel! Use a model car, or just a mock-up with some pieces of wood in the rough shape of a car, a fan of some sort and a cigarette or other smoke source. Try guessing beforehand how the flow around the car's body will be, and I guess you will be quite surprised at the real flow patterns! It is not a very scientific approach, but If nothing else, it's always fun to play with cars!
Olaf.
Author:  Brussell [ Sat Mar 12, 2011 6:25 pm ]
Thank-you Olaf,
I was aware of some of those things but I'm inrested in the idea of cowl induction (have seen that a few times).
Doesn't sound stupid at all my friend has a fog machine and I'll test that out on my car, might even be able to improve some other areas of wind resistance. :/
Author:  Will [ Sun Mar 13, 2011 5:02 am ]
http://s690.photobucket.com/albums/vv26 ... g&newest=1
Author:  Brussell [ Sun Mar 13, 2011 5:07 am ]
Thanks, that's what I'm talking about!
Hopefully I'll be able to borrow the fog machine and take some photos in the next few days.
Author:  Big T [ Mon Mar 14, 2011 8:04 pm ]
Post subject:  Pic
Will....
That is some work of art....Very Nice
Author:  Greg Ondayko [ Tue Mar 15, 2011 2:18 pm ]
http://s690.photobucket.com/albums/vv262/slant6racer/?action=view&current=i17053.jpg&newest=1
I thinks that is the car I kinda saw at Mason -Dixon I in 2010.. when it rained the whole weekend and My engine was puking water into the oil.
Wish i could have seen more of it.
Author:  slantvaliant [ Tue Mar 15, 2011 2:39 pm ]
Lotus-Valiant with a Hyperpak! Who needs a scoop when the whole carb and air cleaner are out in the breeze?
Author:  1974duster kev [ Tue Mar 15, 2011 4:00 pm ]
Well i used my snorkel hoodscoop on the duster to make my ram air fucntional but i had timeslips to prove i picked up a consistent tenth and a mph in the 1/8th mile for free by making it, it was ugly though i took it off at carshows but it worked.
Kev
Author:  Will [ Tue Mar 15, 2011 5:21 pm ]
Yea that is Stan about 10? years ago at Bristol. He did have the car at Mason Dixon. And yes you were busy that day.
Will
Author:  slantzilla [ Tue Mar 15, 2011 6:07 pm ]
They made an aftermarket shaker for Dakota's that was a little smaller than a factory unit. If you could find one of those it might be easier to fit. :D
