Super Sexy
https://slantsix.org/forum/viewtopic.php?t=44025
Author:  soupysocks [ Sun Mar 13, 2011 8:58 pm ]
Post subject:  Super Sexy
Hey Guys,
Just in the middle of putting my build on paper. My future \6 will be tucked under the hood of a early 1980's Power Ram 4x4. I want to make CLEAN! :D 4x4 that is not modded up too much, but has a lot of character rather than go.
I want to bonce some ideas off of you guys to send me in the right direction. I want to make this thing run good and smooth, not looking to make big big power. The only thing modern I plan on running is a TBI system (still have to find out the costs and which one)
I do know that I want the engine bay to be clean as hell with as little hoses and vacuum routing as possible.
So when and if I go TBI, will I have to get a 4bbl manifold? which one works best for going TBI? Also what TBI system has the cleanest look to it?
I plan on moderizing some stuff on it to make it look like a factory TBI set up (I plan on using the duct and airbx from the GEN 1 chrysler 2.2 motor) Other than that I want to see as much metal and motor as possible, what can I hide or elimiate to get this look I am after, while still be reliable, functional?
Thanks, JC
Author:  Brussell [ Mon Mar 14, 2011 3:57 am ]
I personally wouldn't TBI, I thinking finding parts will be a hassle and you could probably get what you are after carb wise + it will look cleaner (In my opinion).
You could put all your relays and wiring that's on the engine bay side of the fire wall on the inside.
I took my own heaterbox out and just got one pipe for those two parts.
You could relocate your battery.
For an improvement in your engine generally port and polish, and bump up compression and upgrade the ignition if needed/possible. I would consider getting a new exhaust manifold, and perhaps a long runner intake manifold.
Ben
Author:  paul_sak [ Mon Mar 14, 2011 6:03 pm ]
Post subject:  la engine
I would go for a 318. That may be heresy on this board but it will give you more power, without a huge decrease in economy. I know there were slant 6 4x4s back in the day but I'm not sure how much fun they were. Plus a v8 would have better resale value if you ever had/wanted to sell it.
If it were me, I would go with a new-style 318 with old-style valve covers and air cleaner housing.
(and yes, I am a huge slant six fan)
Author:  hantayo13 [ Mon Mar 14, 2011 7:50 pm ]
put the slant in it ....i use to pull 440 powered 4x4s around the field wth my slant... laughing all the way also beat to top of hill...did not take long before they quit picking on my leaning tower of power
keep on roddin'
Author:  wjajr [ Tue Mar 15, 2011 6:05 am ]
Soupy, Hantyo13 has a point, six cylinder 4x4’s don’t jump, but smoothly pull when power is applied.
Back in the sixties when mass production of PU trucks equipped with 4x4’s started to become popular, a lot of the woods guys preferred six cylinders in them. In those days most 4x4 PU trucks were standard transmission equipped, so it was easy to brake traction in the slop when shifting gears if the truck had a V8.
Six cylinder power would not chew-up rutted logging roads by wheel spinning, but instead smoothly power up a grade with low rpm torque.
It wasn’t until decent shifting automatic transmissions, and torque converter combinations were fitted to PU trucks did V8 4x4 work trucks become favorable.
As for resale value… That is a moot point, there is none for these old hunks of iron, resale value is the bastion of Hemi Cuda’s and the like.
Build what you like, enjoy your project, and when the time comes to sell, someone will want it. Just hope they really want it, and you will get back some of your dough.
