| 74 dodge dart oil pan? https://slantsix.org/forum/viewtopic.php?t=44035 |
| Author: | 56 Dodge [ Mon Mar 14, 2011 2:10 pm ] |
| Post subject: | 74 dodge dart oil pan? |
Hey I have a 74 dodge dart 225 installed in my 56 dodge pick-up the oil pan has a pin hole in the side probably from all the New York salt over the years. Anyways I also have a 78 225 motor on an engine stand in the garage after looking at the 74 pan it is a center sump and the 78 is a rear sump will these pans interchange or should I just pull the pan and weld the pin hole? also is there any aftermarket or nos pans for the 74 Dart? Thanks and have a Great Day! Jim |
| Author: | slantzilla [ Mon Mar 14, 2011 2:40 pm ] |
The '78 pan has to be a truck pan if it's rear sump. If you have room for it use it. You will also have to use the pickup tube for it too. |
| Author: | 56 Dodge [ Mon Mar 14, 2011 2:46 pm ] |
Thanks yeah room will not be a problem. Thanks again! is it the same gasket? |
