It is currently Sat Nov 14, 2026 3:47 pm
 Post subject: Distributor drive gear
PostPosted: Tue Mar 15, 2011 9:18 pm
Ok so relative to my other post, ive come to find when I turn the engine by hand the rotor does not move, and if it does it kinda twitches a bit. Am I correct in assuming its the drive gear, and just needs replaced? when I turn the engine over I hear the compression so im also assuming that its not the chain. Need some clarification, thanks guys :D
PostPosted: Tue Mar 15, 2011 9:31 pm
6 Pack Dart
Sounds like you have it figured out, remove distributer replace gear.
Richard
PostPosted: Wed Mar 16, 2011 8:26 pm
Yea I pulled the gear, and like a ton of pieces of it as well. Problem solved :D
