| rocker arm ratio https://slantsix.org/forum/viewtopic.php?t=44072 |
| Author: | DadTruck [ Wed Mar 16, 2011 8:04 pm ] |
| Post subject: | rocker arm ratio |
I have seen comments about being able to sort stock rocker arms to find those at 1.5 or better,, to do that with what I have at home in my garage would I. 1) assemble a group rockers to a rocker shaft held level, with v blocks 2) pull the rockers back with a ball inserted in the push rod end and set the bottom of the ball against a level straight edge 3) find the rockers that protrude the furthest downward where the rockers touch the valve stems,, or is there an easier way? |
