It is currently Tue Oct 13, 2026 10:14 pm
PostPosted: Tue Mar 22, 2011 10:30 am
Small bit of info here, probably useless but might be helpful to sombody who can't get to an American parts dealer but has easy access to older British bits and pieces.
The thermostat housing on my slant appears to be a die cast mazak part, and is marked "stanpart 156333"
A little research shows this to fit Triumph Spitfires and Heralds (presumably other . . ?). I've never had any problems getting it to fit (always assumed it was the correct part) and all the holes seem to be the right size and place.
It came with the car - God knows how sombody discovered this but the two work together quite well.
So if there's anybody living in the UK or anywhere else looking for a t-stat housing in a hurry, this might be a temporary fix.
Similarly, if any of you guys over the pond have busted the t-stat housing on your Triumph Spitfire, try this before you go shipping parts across the Atlantic!
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Tue Mar 22, 2011 3:20 pm
Car Model: '23 T-bucket
Would you happen to have a picture you could share?
Roger
PostPosted: Wed Mar 23, 2011 1:56 am
I'll take one later when I get back.
Allthe best,
60 Ply
Stock 60 225
Right Hooker
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 16 guests
