| Holley 6145 connections https://slantsix.org/forum/viewtopic.php?t=44165 |
| Author: | skurdnin [ Wed Mar 23, 2011 3:09 pm ] |
| Post subject: | Holley 6145 connections |
Could someone direct me to a picture of a Holley 6145 that has all the vacuum lines correctly routed to it? I think I finally got mine all set up right, but the FSM I have skips over some of the ports, and the diagram under the hood isn't in the best condition. Thanks! |
| Author: | SlantSixDan [ Wed Mar 23, 2011 8:23 pm ] |
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. |
| Author: | skurdnin [ Thu Mar 24, 2011 11:39 am ] |
thank you. I did see that, but the 1945 is slightly different than the 6145. And looking at my engine today, I think I have it set as correctly as can be without the some of the smog stuff that the prior owner removed. |
| Author: | ESP47 [ Mon Apr 18, 2011 12:26 pm ] |
Do you still need these pics? I took a bunch the other day before I removed mine. BTW - Does anyone know if the 1945 and 6145 throttle shaft bushings are interchangeable? |
| Author: | skurdnin [ Mon Apr 18, 2011 1:26 pm ] |
I don't think I need them anymore. I suppose I'm still not positive if I have everything correct, but it's running fine. If you could post them, it would be appreciated, but no big hurry. |
