| automatic to manual? https://slantsix.org/forum/viewtopic.php?t=4420 |
| Author: | dodge_this! [ Fri Nov 08, 2002 5:50 pm ] |
| Post subject: | automatic to manual? |
| Author: | 87Slant_sickness [ Fri Nov 08, 2002 9:47 pm ] |
hey, well i havent converted my 87 (came factory with a stick) but if you can find a donor truck that has a slant and a stick, you have it made because it sure aint that hard to do.... Justin |
| Author: | Dart270 [ Sat Nov 09, 2002 6:55 am ] |
| Post subject: | not too bad... |
The best way is to find a Van or 2WD PU with an 833 4spd or "833OD" 4spd and pull all tranny/clutch-related parts from it. Swapping these things around is not too bad on pickups, although it will take some work. Make sure to get everything - including crossmember, shifter, pedals, clutch linkage, driveshaft... There should be a fair number of these things in the junkyards if you look around. Lou |
