| Lowering blocks https://slantsix.org/forum/viewtopic.php?t=44205 |
| Author: | SMOKEY [ Fri Mar 25, 2011 4:26 pm ] |
| Post subject: | Lowering blocks |
Can some one tell me where we can get some blocks to get the car down in the rear. Car is 69 Valiant. Thank's Smokey. |
| Author: | Joshie225 [ Fri Mar 25, 2011 4:38 pm ] |
Lots and lots of places have them. Make sure they are 2 1/2" wide and are not die-cast. The die-cast ones break. I used cast iron "lift" blocks from Summit and ate the weight penalty. |
| Author: | SMOKEY [ Fri Mar 25, 2011 6:21 pm ] |
| Post subject: | blocks |
Thank's for the info. Are they for the 7 1/4" rear end ? SMOKEY. |
| Author: | Joshie225 [ Fri Mar 25, 2011 6:30 pm ] |
They are for 2.5" wide leaf springs. |
| Author: | SMOKEY [ Fri Mar 25, 2011 7:56 pm ] |
| Post subject: | axel |
I got the spring size. Looking for axel tube size. Thank's . |
| Author: | Joshie225 [ Fri Mar 25, 2011 10:09 pm ] |
Irrelevant. |
| Author: | ceej [ Sat Mar 26, 2011 11:03 pm ] |
Need to buy new U-bolts long enough to handle the blocks? I will measure the tubes on the 7-1/4's piled under my back deck tomorrow for you! Perhaps somebody can chime in that knows off the top of their head before then. CJ |
| Author: | Greg Ondayko [ Sun Mar 27, 2011 6:28 am ] |
Early 7.25' ( small Bolt Pattern) Use smaller axle tubes - Either 2.75" or 2.5" tubes. The later ones (big BOLT Patt) use the more standard 3" axle tubes Like the 8 3/4" Just take one u bolt off even if it breaks and take to any local spring shop, They can make u bolt for you usually while you wait. Greg |
| Author: | SMOKEY [ Sun Mar 27, 2011 10:59 am ] |
| Post subject: | low blocks |
Thank's two all for the help. SMOKEY. |
