| Air https://slantsix.org/forum/viewtopic.php?t=44216 |
| Author: | Brussell [ Sat Mar 26, 2011 9:00 am ] |
| Post subject: | Air |
Hey, Is it better to have hot air going into the engine, or cold air, and yes I am aware that hot and cold is relative, but I think you will get what I mean, heat for example will be hotter than normal intake air because piping has run near exhaust pipe for example. I believe the fuel should be hotter, to help with the combustion. But I thought it would be better to have a colder air intake as the air will be more dense. Thanks! |
| Author: | SlantSixDan [ Sat Mar 26, 2011 9:11 am ] |
Things work best when the intake air temperature above the carburetor is between about 60°F and 100°F. That's what the '70-up thermostatic air cleaners are calibrated to provide to the carburetor. Leave the "heat for vaporizing fuel" job to the manifold heater. |
| Author: | Brussell [ Sat Mar 26, 2011 9:16 am ] |
Thanks, That seems like it should be a fairly easy goal. Planning to run my air intake piping to the filter past the exhaust manifold I have, hopefully to get within that temp range. Going to have lots of fun with piping on my hoilday break! |
