It is currently Fri Oct 09, 2026 11:36 pm
 Post subject: Engine Block I.D.
PostPosted: Mon Mar 28, 2011 2:19 am
Hi Guys,
What can you tell me about this engine from the block casting number?
4095530
I'm about 300 miles from the engine but if the price is right then it'd be well worth me picking up, these engines are few and far between this side of the pond.
Thanks a lot,
60 Ply
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Mon Mar 28, 2011 5:47 am
Check here.
PostPosted: Mon Mar 28, 2011 12:50 pm
Hmmm, checked through the two sections in there and couldn't find it. I've searched for the number elsewhere and haven't turned anything up.
If I find anything else I'll post it.
Stock 60 225
Right Hooker
PostPosted: Mon Mar 28, 2011 1:39 pm
That is an interesting casting number... one I have not seen in the past.
The 40XXXXX would indicate something released in the mid seventies.
Is this number casted into the side of the block?
PostPosted: Mon Mar 28, 2011 6:57 pm
Doug might that be from RSA? I think they had some casting number like that.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Mar 28, 2011 11:28 pm
'82 passenger car parts catalogue lists 4095 527 as a vibration damper and 4095 776 as a cylinder head for a 225, doesn't have a p/n for the bare block, just for the short block assembly. Part numbers often aren't the same as casting numbers, but they are frequently within a few digits. I am with Doug; guessing late '70s or early '80s RG cast-crank block.
PostPosted: Tue Mar 29, 2011 1:30 am
Sounds good guys,
Got a few more points to add - the engine has just been removed from a camper (dodge 50?), however, this is NOT the original motor in that van. The seller also says he believes the trans is a 727 - presumably this makes the combo a truck/heavy duty package? I suppose the engine could be non-original but from another dodge 50 given the spec.
Stock 60 225
Right Hooker
Users browsing this forum: No registered users and 32 guests
