| Odd A-833 Transmission? https://slantsix.org/forum/viewtopic.php?t=44244 |
| Author: | Old Car Scott [ Mon Mar 28, 2011 9:24 am ] |
| Post subject: | Odd A-833 Transmission? |
I just finished up the mechanical work on my Valiant and was able to get out and stretch its legs a bit this weekend, but I made a bit of an interesting discovery. I converted over to a four speed, the tranny I swapped in is a short tail A-833 with the big 5.125 input bearing retainer and a 1975 date code. I love the OD tranny and this is probably my sixth four speed conversion. However, this particular transmission is not an Overdrive! It has the standard gear ratios and the 3/4 gears are not flopped, much to my surprise when I though I was going to pull it into OD on the freeway! Anyone else have a standard ratio tranny with the large IBR? I always assumed the large IBR indicated an OD tranny. |
| Author: | DusterIdiot [ Mon Mar 28, 2011 5:23 pm ] |
| Post subject: | Lol... |
Quote: Anyone else have a standard ratio tranny with the large IBR?
You can swap the guts from the regular to the OD casing if needed (with proper bearings/etc...). Unless you totally grenaded the case I'm not sure why you'd do it. -D.idiot |
| Author: | Old Car Scott [ Tue Mar 29, 2011 4:45 pm ] |
Well, that's just freakin' super. At least I can drive it. Guess I'm still looking for an actual A-body overdrive four speed.... |
| Author: | DusterIdiot [ Tue Mar 29, 2011 6:25 pm ] |
| Post subject: | One other way... |
I forgot there is one other way to make that work...in 1975...the 3 speeds still had the bolt pattern for the small IBR...mopar made a special IBR for them that will fit a OD bellhousing but has the same bolt pattern as the older straight A-833s and 3 speeds...If you didn't mind a straight across trade on your current box, and if it's in good shape, I do have a 1978 A-833OD that was rebuilt 8 years back (works great, just pulled it in lieu of a iron cased OD for drag racing). -D.Idiot |
| Author: | ditzola [ Thu Apr 07, 2011 7:11 am ] |
hey, i have here my standard ratio used transmissions for sale at an arizona transmission shop with the large IBR,im looking for a buyer, pm me if you want |
