'91 D150 318 -> /6 swap.
https://slantsix.org/forum/viewtopic.php?t=44250
Author:  CrAlt [ Mon Mar 28, 2011 5:03 pm ]
Post subject:  '91 D150 318 -> /6 swap.
I building a franken-ram based on a 91 D150 frame. It had a v8/727 in it.
I have a /6 i plan on putting in when i find a 727 for it but I do not know what I need for mounts. I'll also be converting the truck to 4wd :lol:
Are there different cross members for v8 vs /6 trucks? Or are the mounts that bolt the the engine the only difference?
Author:  66aCUDA [ Mon Mar 28, 2011 6:54 pm ]
I dont know whether the K member on the trucks is different or not if not I have the truck slant six mounts. You will need the slant radiator. hoses are on different sides.
Dont know what else.
Frank
Author:  DusterIdiot [ Mon Mar 28, 2011 7:49 pm ]
Post subject:  I think...
I've been told up through 1993, that the K-members are still sandwich type like their older bretheren.
Anybody else be able to confirm?
Author:  Reed [ Tue Mar 29, 2011 8:38 am ]
I can confirm. Dodge vans and trucks at least through the 80s used one K-member and the sandwich style mounts. You should be able to use the original K-member and get the motor mounts, oil pan, and matching oil pickup out of any 79-up slant six van or any 71-up (I think) slant six truck. I know the 71-78 vans used a different k-frame, but the motor mounts may be the same. In fact, there is so much clearance between the k-frame and the bottom of the block that you can actually use passenger car oil pans and pickup in the truck or van engine bay. That might give you a smidge more ground clearance if you are going off roading.
