It is currently Sun Oct 11, 2026 11:21 am
PostPosted: Fri May 20, 2011 3:59 pm
I’m looking for the plastic bushing, for lack of a better term, that a trim screw would thread into to secure headlight bezels to my 1967 Dart as pictured below. I suspect that the same part was used on 68 & 69 models.
In the photo below, one of the factory bushings is install in upper right of headlight. Lower right bushing is missing leaving a small square hole where one would be inserted.
Previous owner had drilled sheet metal adjacent to bushing to receive a sheet metal screw. This method of attachment is not working out to well, as these holes are getting too large to hold a screw securely.
Bill
PostPosted: Fri May 20, 2011 8:49 pm
Little things like that are a bear to find. You have to match the screw hole size and the square hole size. Most body shops have a junk box full of things like that and can sort through and find something that will work. I'll try to find mine - it's been packed up for a while. If you can get a measurement of the square hole it would help. You might also find something like that in the "HELP" rack at NAPA but I assume you've already tried that.
Danny
PostPosted: Fri May 20, 2011 10:33 pm
Measure the holes and pm me, I have some for a '74 not sure it's the same size though
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Sat May 21, 2011 5:48 am
At least one of the outfits listed here will have them.
