| Fully syncro 3 speed https://slantsix.org/forum/viewtopic.php?t=4427 |
| Author: | Shad's 65 [ Sat Nov 09, 2002 2:13 pm ] |
| Post subject: | Fully syncro 3 speed |
I know my 65 Dart has a manual 3 speed (on the tree) without a synchro 1st gear. It can be tricky to drive in town sometimes. Is there a fully synchro three speed that is a direct bolt up? My car is all stock and I hate to start to alter things just yet, just would like to change a few small things. |
| Author: | Doctor Dodge [ Sat Nov 09, 2002 8:01 pm ] |
| Post subject: | 3-speed swap options |
Here is a link to some info. http://www.slantsix.org/articles/4-spee ... -swaps.htm There is not a direct bold-in but there are some options. The 4-speed swap is the way to go. DD |
| Author: | valiant convert [ Sat Nov 09, 2002 8:17 pm ] |
| Post subject: | 3 speed swap options |
i have an A 230 in my 80 volare. its complete and i just went thru it. if i end up parting out this car, i would sell it, along with shifter and bellhousing. |
| Author: | callpaladin@aol.com [ Sun Nov 10, 2002 5:40 am ] |
| Post subject: | transmission and rear end |
regarding question on the A230 3speeed manual- does anyone have a 3spd factory floor shifter for bolt up to this transmission. seems they have just about disappeared. would appreciate knowing if one is available in the sl6 forum. thanks callpaladin@aol.com |
| Author: | valiant convert [ Sun Nov 10, 2002 7:15 am ] |
the trans i mentioned comes with the floor shifter if anybody is interested, and if i decide to part the car out after all. i am still undecided about its fate. its a clean little car, runs nice, but i am having a hard time tracking down the title. so it might become "valiant fodder" after all. if so, i'll let the list know. also has the hump that looks as if it could be made to work in an A body, as the F body and A shared the same transmissions |
| Author: | Chuck [ Sun Nov 10, 2002 2:17 pm ] |
| Post subject: | Re: transmission and rear end |
Quote: regarding question on the A230 3speeed manual- does anyone have a 3spd factory floor shifter for bolt up to this transmission. seems they have just about disappeared. would appreciate knowing if one is available in the sl6 forum. thanks callpaladin@aol.com
You should post in the Parts Wanted forum.
| Author: | Guest [ Tue Nov 12, 2002 11:46 am ] |
i will when i finally decide if i really want to part the volare out or drive it |
| Author: | Chuck [ Tue Nov 12, 2002 5:29 pm ] |
I was referring to callpaladin. |
| Author: | Chuck [ Tue Nov 12, 2002 5:32 pm ] |
Quote: It's a clean little car, runs nice, but I am having a hard time tracking down the title.
In California, you used to be able to send a registered letter to the last owner of the car, and if you got no response, you could take that letter into the DMV and have the title issued to you. You should check out the rules in your state.
