Checking valve clearance
https://slantsix.org/forum/viewtopic.php?t=44285
Page 1 of 1
Author:  Dizzydean [ Thu Mar 31, 2011 4:34 am ]
Post subject:  Checking valve clearance
I couldn't find any info on how to check valve to piston clearance so I did my own. Filled the remaining space in 2 cylinders after hitting the top with clay, snugged the head with push rods, turned crank enough times to see the valves move, checked clay. That should be it right :?: (thanks(again)
Author:  SlantSixDan [ Thu Mar 31, 2011 8:05 am ]
Yup, that works. Make sure you do it with the same type of head gasket you will be using in the final assembly.
Author:  Dizzydean [ Thu Mar 31, 2011 6:58 pm ]
Thanks Dan this is almost getting to be easy. One day I'll be the one giving help.
