| volare rear in a 64 valiant??? https://slantsix.org/forum/viewtopic.php?t=4430 |
| Author: | valiant convert [ Sat Nov 09, 2002 8:13 pm ] |
| Post subject: | volare rear in a 64 valiant??? |
i have 2 volares and one has the 8 1/4 rear. will they work in an early A body? ie, are they too wide? thanks again |
| Author: | Wesola78 [ Wed Nov 13, 2002 8:20 am ] |
I don't know if the Volare rear is too wide, but I know that its wider than an A-body rear. You also might have to move the spring perches to use this rear in your Valiant. Hopefully, someone else will know for sure. |
| Author: | kesteb [ Wed Nov 13, 2002 12:01 pm ] |
The Volare rearend is to wide for a '64 Valiant. |
| Author: | valiant convert [ Wed Nov 13, 2002 12:55 pm ] |
thanks, i was afraid of that. i have another option with a 75 duster that a friend has stilling in the woods. V8 car, it could have a 8 1/4 in it. either way, i will be getting the front end components off of it. |
| Author: | Doc [ Wed Nov 13, 2002 3:32 pm ] |
| Post subject: | Rear End Swap |
The 75 A-Body rear end will swap in. If it's an 8 1/4 the drive shaft will have to be shortened. Also use the parking brake cables off your 64. DD |
