It is currently Tue May 19, 2026 12:49 am
 Post subject: Brake booster
PostPosted: Fri Mar 25, 2011 6:36 pm
Hi,
I got the chance to get a recon VH24 brake booster, I currently have an Abody with drum brakes all around. It'll cost me $25.
Will it make a reasonable difference?
Is it easy to install?
Cheers!
PostPosted: Mon Mar 28, 2011 9:22 am
Changing over will be hard if you do not have all the special mounting brackets and hardware for you year vehicle and chassis type.
PostPosted: Sat Apr 02, 2011 4:00 pm
I googled the VH24 booster, it looks like it could work , if you have & wanted to keep a single circuit brake system. (but why would you :?: )
I don't know how much pressure the VH24 can add, but I always felt that most power drum systems had too boost & were quite difficult modulate under heavy braking.
Having owned several drum brake A bodies, I never found anything wrong with the front brakes that a disc conversion couldn't fix.
63 Valiant Wagon
225 - 4 bbl
