How to ID Super Stock leaf springs?
https://slantsix.org/forum/viewtopic.php?t=44329
Author:  Rob Simmons [ Sun Apr 03, 2011 7:49 am ]
Post subject:  How to ID Super Stock leaf springs?
Title says it all.
I THINK the Street Duster has SS springs, but I'd like to verify and make sure before I do some planned swapping around.
Author:  Rick Covalt [ Sun Apr 03, 2011 12:31 pm ]
Post subject:  crooked
Does it set crooked? Cocked towards the passenger side? Any chance there are numbers left on the springs?
Rick
Author:  Rob Simmons [ Mon Apr 04, 2011 6:25 pm ]
It doesn't really appear to sit crooked. I'll crawl up under there and look a little closer at things.
I thought there was a different leaf count or clamp arrangement on the SS springs.
Author:  Rick Covalt [ Mon Apr 04, 2011 6:58 pm ]
I think the SS springs do twist the car towards the passengers side a little bit. Also the SS spring eye bolt was larger than the stock 72 swinger springs Tell me what you have Rob and I can look at Ryan's Dart. That is what he has on his car
Rick
Author:  Romeo Furio [ Tue Apr 05, 2011 8:46 am ]
Post subject:  S/S springs
Numbers should be stamped(not painted on) into the spring pac near the mounting pad. Look for a 002 on one 003 on the other. that is the most common for a A-body like a Duster, 3000 lbs. 863/864 2800lbs, 456/457 3400 lbs.
Author:  Romeo Furio [ Tue Apr 05, 2011 8:48 am ]
OOps, Should have said U-bolt mounting pad.
Author:  Rick Covalt [ Tue Apr 05, 2011 11:08 am ]
Post subject:  numbers
That is the correct numbers, but Ryan's came in with the numbers stenciled, painted , on the springs. They may be stamped too but I'd have to check.
Rick
Author:  Rob Simmons [ Wed Apr 06, 2011 7:09 am ]
Thanks for the info guys. :D
I'll get over there and crawl up under it to see what I can see.
Author:  Romeo Furio [ Wed Apr 06, 2011 9:42 am ]
Sometimes I forget how many years we been doing this.Some have both paint and embossed, some just paint. Went and looked at the newest ones bought (about 2006) and they were painted. :oops:
