It is currently Sun Nov 15, 2026 10:49 am
 Post subject: Carb help
PostPosted: Mon Apr 04, 2011 2:51 am
Getting a 350 holley, and it has 58 jets as it was for a 2L engine (well that's what I was told) I don't know alot about it but what would you recommend me to get for my 225?
And would someone without carb experience (like me) be able to put them in?
225 has port polish, headders new ignition, will have higher comp and slightly bigger valves 1.7 and 1.44.
thanks!
PostPosted: Mon Apr 04, 2011 4:40 am
Out of the box the 350's have 61 jets, 85 Power Valve and 31 fuel discharge nozzle (fuel shooter). That's a good place to start. FWIW my 350 has 63 jets, 65 PV and 31 shooter.
Holleys are easy as to work on. Just rip into it mate !!! :D There's heaps of info online with regards to changing jets etc. If you get stuck you know where the help is. :wink:
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
Users browsing this forum: Google [Bot] and 9 guests
