| bad coil https://slantsix.org/forum/viewtopic.php?t=44341 |
| Author: | ARMYdodge83 [ Sun Apr 03, 2011 6:02 pm ] |
| Post subject: | bad coil |
i know this is a electrical 101 question but here it is. when you have power at the + post and no power at the - post coil is good. but when you have power at + and the - post coil is probably bad right? |
| Author: | wjajr [ Mon Apr 04, 2011 6:43 am ] |
Simple test of coil here. How a coil works and what you are testing when using a VOM here. A coil is nothing but a transformer where primary (low voltage) to secondary (high voltage) ratio of windings determines how much impute voltage as stepped up. Kind of like a lever & fulcrum is to mechanical advantage. Brake one of those wires, or short them out, and it won't work. Keep in mind sometimes heat or vibration will cause coil conductors to fail, but when unit is cold it will test as good. |
| Author: | 4speed [ Mon Apr 04, 2011 8:53 am ] |
It would help if we knew if you have a points system or electronic. |
| Author: | ARMYdodge83 [ Mon Apr 04, 2011 9:48 am ] |
electronic distributer for a 83 d150 225 its a cordone model. |
| Author: | 4speed [ Mon Apr 04, 2011 10:50 am ] |
The only time the minus (-) of the coil will have zero volts is when the electronic ignition is triggered by the distributor (it has to be turning). It will show plus 12 volts on the coils minus terminal if the engine is not running. Same with points-if the points are open you get +12 volts on the minus terminal and zero when they are closed. |
| Author: | ARMYdodge83 [ Mon Apr 04, 2011 3:09 pm ] |
okay so as the truck is not running and the ignition key on i will have power at all both terminals got it. so any clue on why it wouldn't start right off the bat. i'm going to take a video and pics of my set up and try to explain everything i have done and then i'm sure every one will have lots of troubleshooting for me. thanks for that explanation. |
| Author: | 4speed [ Mon Apr 04, 2011 5:15 pm ] |
I take it that your truck does not start-what are your symptoms? Does it crank but not start until you let go of the key? Do you have spark at the distributor's center wire? Do you have "Lean Burn"? |
| Author: | CStryker [ Mon Apr 04, 2011 5:21 pm ] |
Do you have the spark control computer mounted on the air-breather? If so, ignore everything I wrote below the dashed line and strongly think about doing the HEI conversion. You will need an older distributor if this is the case, but they are relatively easy to pick up (and just do yourself a favor and replace the gear before you install it). ------------------------------------- Could be the Ignition module... many autoparts stores will test them for free. I know O'Reilly's up in Rolla used to but I've heard rumors that they don't anymore. I would call around the parts stores down in the St. Robert area to see if any of them will. I've always been told to make sure they test it several times in a row; that will build the heat up a little to make sure it's not failing at operating temperature. Could also be the pick-up coil. A simple resistance check is all that's needed. I don't remember the factory spec (it's been a while), but I'm sure someone else on the board can provide it. Could also be any other number of things, but I would check those two first. |
| Author: | ARMYdodge83 [ Mon Apr 04, 2011 6:02 pm ] |
well i appreciate it. but it seems to have started after i ran a jumper wire to a good engine ground. who would have known!! |
| Author: | Joshie225 [ Mon Apr 04, 2011 7:14 pm ] |
Wait, you ran a wire from the negative side of the coil to ground??? |
| Author: | ARMYdodge83 [ Tue Apr 05, 2011 3:45 am ] |
sorry ill clarify i ran a jumper wire from the module hold down bolt to a better ground. |
| Author: | 4speed [ Tue Apr 05, 2011 5:28 am ] |
Great-ground is good! |
| Author: | 61 V200 [ Tue Apr 05, 2011 6:19 am ] |
| Post subject: | wjajr |
Thanks for the link to "Coil Testing". I tried it on the newer style high energy coil out of a 97 GMC and got results not close to those expected in the article. Any more thoughts on this? Thanks Just now found this. 1.Circuit labeled A -Pink Wire: Power (12 V) Circuit. 2.Circuit labeled B -White Wire: Tach Signal for the Tachometer in the Instrument Cluster if equipped. 3.Circuit labeled C -White with Black stripe Wire: Switching Signal Circuit. This wire (circuit) comes from the Ignition Module. Would #3 wire be coil neg? Thanks |
