| Only One Master Cylinder Reservoir? https://slantsix.org/forum/viewtopic.php?t=4436 |
| Author: | Frank G [ Sun Nov 10, 2002 11:01 pm ] |
| Post subject: | Only One Master Cylinder Reservoir? |
I am restoring my car piece by piece and I was wondering if I could install and bleed the front brakes without having to have the rears hooked up, you know, just leave the rear reservoir empty. Would I just plug the unused M/C outlet? Thanks. Francisco |
| Author: | Doc [ Mon Nov 11, 2002 1:41 pm ] |
| Post subject: | Bench Bleed the Master Cylinder |
It is possible to bench bleed the master cylinder, then plug the rear port and bleed the front. If your car has a brake system emergancy switch / light I would not advise doing this because it will trip the switch. ( system pressure imbalance) These switches are hard to get recentered once they are activated / moved. Look for a electrical wire going to the metering block. What year is the car? DD |
