It is currently Tue Nov 17, 2026 12:15 pm
 Post subject: B&M shift improver kit
PostPosted: Mon Apr 04, 2011 2:46 pm
Does anyone have the part no for the b&m shift kit improver? The only one I can find is for the V8 904. Is this the same for the slant 904? Is this an easy job to do or do I need to look out for something in particular?
PostPosted: Mon Apr 04, 2011 3:49 pm
V-8 and Slant should be the same kit. It will have directions in it for all the different valve bodies it covers.
904 and 727 are usually the same kit too. :shock:
PostPosted: Mon Apr 04, 2011 3:54 pm
One word: TransGo
PostPosted: Mon Apr 04, 2011 4:21 pm
Where do I get a transgo kit from? And what's the difference?
PostPosted: Mon Apr 04, 2011 9:52 pm
transgo kits are available through summitracing, and if your lucky to have a local transtar near you, you can just go pick it up, options are one of the many reasons i like the transgo TF-2 kit i got. basically its both b&m kits in one, execellet quality, great clear instructions, and price ain't bad either,
-Mike
PostPosted: Tue Apr 05, 2011 5:50 am
Thanks just checked ebags there on there I see!
