It is currently Thu Nov 12, 2026 11:05 am
PostPosted: Wed Apr 06, 2011 7:45 pm
:roll: My son and I inherited a Dodge 87 D100 we have be trying to keep running. All was good till he hit a bump on the right side and it started running rough. We tore into the carb and found black bits which I was told was from the canister. The replacement is expensive so was wondering about creative ways to keep her going until he can afford the part.
USMC Texas
PostPosted: Wed Apr 06, 2011 8:58 pm
The ruptured charcoal canister was a common method of demise for many a D-series truck. The probability of getting all the charcoal bits out of the carb is nil. If you really need one, you can replace the charcoal inside your existing canister. I just tossed mine in the garbage because my new carb has no vacuum lines for it, or I would have given it to you. Bad timing I guess.
PostPosted: Thu Apr 07, 2011 5:47 am
I have heard of folks adding a fuel filter to the vaccum line to catch the carbon,, don't know if it a good long term fix,, never did it myself.
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
