It is currently Wed Sep 30, 2026 6:36 am
PostPosted: Fri Apr 08, 2011 1:28 am
Well, I've settled on a Carter AFB for my blow through turbo setup, simply because I have one. I found a lot about the mods necessary, but nothing about referencing the needles for boost. it is a needle and jet setup unlike Holley's power valve, but it works in the same way; with a vacuum signal from under the carb.
Pretty sure this has to be referenced to boost, rather then vacuum, but I can find nothing about how to do it on the web, or even if it can be done.
Does anyone know?
________
Discuss vaporizers
 Post subject: AFB Blow Thru
PostPosted: Sat Apr 09, 2011 6:19 pm
Go to Yahoo, Select Yahoo Groups, Select group called carburetedblowers its on there first page 6 or 7 groups down. When on site go to photos left upper corner go onto AFB mods photos, might help you
PostPosted: Mon Apr 11, 2011 10:49 pm
Also do a google on Studebaker R2 and R3 and Paxton. They used AFB's in a blow thru setup.
