Carter AFB blow-through boost referencing.
https://slantsix.org/forum/viewtopic.php?t=44396
Page 1 of 1
Author:  polkat [ Fri Apr 08, 2011 1:28 am ]
Post subject:  Carter AFB blow-through boost referencing.
Well, I've settled on a Carter AFB for my blow through turbo setup, simply because I have one. I found a lot about the mods necessary, but nothing about referencing the needles for boost. it is a needle and jet setup unlike Holley's power valve, but it works in the same way; with a vacuum signal from under the carb.
Pretty sure this has to be referenced to boost, rather then vacuum, but I can find nothing about how to do it on the web, or even if it can be done.
Does anyone know?
________
Discuss vaporizers
Author:  Supercharged SL6 [ Sat Apr 09, 2011 6:19 pm ]
Post subject:  AFB Blow Thru
Go to Yahoo, Select Yahoo Groups, Select group called carburetedblowers its on there first page 6 or 7 groups down. When on site go to photos left upper corner go onto AFB mods photos, might help you
Author:  kesteb [ Mon Apr 11, 2011 10:49 pm ]
Also do a google on Studebaker R2 and R3 and Paxton. They used AFB's in a blow thru setup.
