| 75 dart sport rear https://slantsix.org/forum/viewtopic.php?t=4440 |
| Author: | elam [ Mon Nov 11, 2002 5:55 pm ] |
| Post subject: | 75 dart sport rear |
This year at clay city I ran my 75 dart sport with a 59 Edsel rear in it. The great thing is that it bolted in was the same width and is a 9 inch ford which has about any gear ratio you want at the junk yard. I'm not sure but i'd say late 50's and early 60's ford rears are the same. The drive shaft even worked with a 319 u joint from NAPA bolt in all the way the parking brake cables even hooked up. Just thought you would like to know. |
| Author: | DusterNut [ Tue Nov 12, 2002 8:01 pm ] |
if you ever want to get rid of that rear end let me know! ford 8" rears out of a granda will fit an a-body too. for more info on ford 8 and 9" rear ends, check out the links below. http://66.96.130.106/archives/2002/02/n ... dex2.shtml http://www.kevinstang.com/Ninecase.htm http://dfwmotorsport.com/Fairlane/9inchrearends.htm http://ultrastang.com/Rearinfo.asp?Page_ID=1 |
| Author: | elam [ Wed Nov 13, 2002 6:28 pm ] |
| Author: | DusterNut [ Wed Nov 13, 2002 8:45 pm ] |
im sure shipping wouldnt be cheap |
| Author: | Guest [ Thu Nov 14, 2002 10:24 am ] |
| Author: | DusterNut [ Thu Nov 14, 2002 9:17 pm ] |
im going to get a 8.25 out of a 75 Dart with a sure grip and 3.23s for 100$ |
| Author: | elam [ Fri Nov 15, 2002 7:46 pm ] |
