It is currently Sun Nov 08, 2026 1:49 am
 Post subject: Head Work
PostPosted: Fri Apr 08, 2011 6:35 pm
Good evening all,
I pulled the motor out of the Swinger this week. Took some measurements, and this is what I have.
deck hgt. .179
chamber 47 cc
bore 3.44
stock valves 1.36/1.62
looking for 40 cc's, another.050 off should get me that, and a set of direct fit big valves[direct fit length and diamiter]. With a felpro gasket I should get about 9.5:1 CR.
Does this sound correct?
Thanks always for your help.
The surgeon general never said that smoking the competition was bad for your health.
PostPosted: Fri Apr 08, 2011 7:52 pm
Based on a 3.50 bore, .034 thick Fel Pro, I get,
8.89 with 47cc
9.66 with 40cc
Slant Cecil
PostPosted: Sat Apr 09, 2011 3:01 am
Bore is 3.44. .040 over. Looking for the same size stem, in a bigger valve.
PostPosted: Sat Apr 09, 2011 4:47 am
Very reliable E-bay seller.
http://cgi.ebay.com/ebaymotors/225-slan ... 5adfdde0ae
Also has a listing for these same valves, with 340 type valve springs, and locks, as a package deal.
PostPosted: Sat Apr 09, 2011 7:09 am
When I posted 3.50 bore, that was for the Fel Pro. I used 3.44 cyl bore for the CR calc.
Slant Cecil
PostPosted: Sat Apr 09, 2011 12:43 pm
Yep ebay eng builders valves i have two heads with them in. Curious has anyone ever flowed a head before and after the install of bigger valves what kinda gains based on just a bigger valve?
Kev
