It is currently Fri Oct 09, 2026 7:32 am
PostPosted: Mon Apr 11, 2011 8:29 pm
Check this out. Put this "great running" 1920 on my friends 64 and it was perfect when it left. He gets home after a 30 minute fwy trip and the thing is leaking gas big time. Takes it to his mechanic and the guy tells him he is lucky to be alive in no less terms. This hole appeared in the accelerator pump circuit, and its a friggin HOLE, not a crack or anything you might expect to see from working 44 year old carb. Where did it come from, previous repair job? Lead plug come out? Area around the hole looked a little leather textured instead of the relatively smooth casting. I though it got so hot it melted! Almost looks like that. It would shoot a jet of gas rearward out his hole whenever he hit the pump, scary!
PostPosted: Tue Apr 12, 2011 4:01 am
Checked all my 1920 carbs. All have this hole.
PostPosted: Tue Apr 12, 2011 7:13 am
So if gas is getting out of this hole, is the accelerator piston seal shot?
PostPosted: Tue Apr 12, 2011 3:22 pm
Might be the float is stuck to high or his fuel pump is a higher pressure that yours and is flooding the carb
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Tue Apr 12, 2011 4:27 pm
Turns out this IS the weep hole for a blown accelerator pump diaphragm. Just replaced it 10 minutes ago, it was shot. Now why they put this hole to vent to a hot exhaust manifold boggles my lawyers mind. Another slanty told of 1920's being fire hazards, I believe him now whole heartedly. If I ever run another Im plugging this hole with a piece of lead buckshot. If my diaphragm starts to go, ill know in other ways besides a fuel wash onto my exhaust manifold. Of course my Holley 2300 is in the same position, diaphragm hanging over the exhaust but its far enough to drip to the side. Be aware, safety first. Happy motoring!
