| Swap Torqueflight automatic for Manul Transmission? https://slantsix.org/forum/viewtopic.php?t=44478 |
| Author: | jdr [ Mon Apr 11, 2011 8:50 pm ] |
| Post subject: | Swap Torqueflight automatic for Manul Transmission? |
Hey Guys, Hello, I'm brand new here. I'm also brand new to working on cars/vans. I have a buddy helping me with swapping out a bad slant six (3 of the cylinders have nearly no compression.) on my '77 B100 shorty Dodge Van. On the engine we are considering buying, my buddy asked if we will have trouble installing the existing manual 3-speed transmission on to a slant six from a '73 Duster that used to have a torqueflite automatic. He is wondering about the flywheel match, etc. Should we be concerned about this transmission at all as long as the original engine (manual or automatic) was a three speed? Any help would be appreciated! Thanks! --JR |
| Author: | Joshie225 [ Mon Apr 11, 2011 9:21 pm ] |
The '73 engine will bolt right in once you swap the oil pan, pickup and dipstick. The crank should be drilled for a pilot bushing, but there may not be one installed. Also, the crank may be drilled, but not finish reamed. If a standard pilot bushing doesn't fit you can get one with a smaller OD or use a roller pilot bearing from a later model truck. Easier though may be to fix the engine in the van. It's likely the van went without necessary periodic valve adjustments and just has burned exhaust valves. You can swap the head from the '73 engine onto the '77 engine in the van, but I personally prefer to fix the original head and have hard exhaust seats installed if the budget permits. |
| Author: | jdr [ Tue Apr 12, 2011 6:29 pm ] |
Thanks for the reply Joshua! My buddy and I talked about using the old engine but the current one is beat real hard and may have one thing fail after another. We do not have the time to do all that work so we thought it better to swap it out for a cleaner/better shape one. Like you brought up, we suspect this current engine did not get any maintenance and was also beat/driven hard. When I got a quote for the rebuild of my current one by a shop they said $2500 for the rebuild plus more for labor to reinstall it (came to like $3400). Seems kinda steep if I can track down another decent lower mile one for less than $500 and get my buddy to help drop it in? |
| Author: | ESP47 [ Wed Apr 13, 2011 8:40 am ] |
Yeah thats too steep. You should be able to get it rebuilt in the $1000 range. No need to pay anyone to install it. Just get a buddy and a cherry picker and have at it. I bought a slant from a guy a few towns over and he pulled it out without even getting under the car in what seemed like less than half an hour. Of course it takes a little longer to put back in but it beats paying $900 in labor for it. Update your profile so it says where you're from and put a want ad in the parts wanted forum. You may get guys chiming in with motors they'll sell you for cheap. Josh has a short block in there for a good price. I'd always pay extra for a motor built by a respected board member because you know you're going to get something of good quality that you don't have to worry about. |
| Author: | jdr [ Mon May 02, 2011 11:58 am ] |
Good Tip. I just updated my profile to reflect my Location (Minneapolis, MN). On a rebuild; if someone knows someone who can do a good job in the twin cities, MN for $1K or so let me know. |
| Author: | jdr [ Sun May 08, 2011 11:04 pm ] |
Picked up my new old slant engine this past Friday with my buddy. Does anyone know where to get the pilot busing? Anyone have the part number and details where to buy it? Thanks! --JR |
| Author: | Charrlie_S [ Mon May 09, 2011 3:52 am ] |
Quote: Good Tip. I just updated my profile to reflect my Location (Minneapolis, MN).
You will be hard pressed to get a quality rebuild for $1,000. You could have new rings and bearings, installed for less then a thousand, but not a complete rebuild. The parts and machining work alone will cost that much.On a rebuild; if someone knows someone who can do a good job in the twin cities, MN for $1K or so let me know. I am doing an engine for another site member, and have been "shoping" parts, and I get special pricing on machning, and will have close to $1500 in it without any labor. This motor does have a few "extras", like stainless oversized valves, Erson cam, and some mild porting. |
