It is currently Sun Oct 11, 2026 1:20 pm
 Post subject: Timing chain gear ID
PostPosted: Mon Apr 18, 2011 4:05 pm
Hi Folks,
I just tried installing a new timing chain set from Cloyes. I have a 65 Dart with a newer (5 freeze plugs) 225 engine. The diameter of the crank shaft is 1.531 and the new gear ID is 1.564. Does anyone know if the crank dia. changed over the years or if I might have a different engine than what I think?
Ken
65 Dart Convertible Super Sixed
PostPosted: Mon Apr 18, 2011 5:31 pm
The crank is "stepped". The dia where the crank gear mounts is 1.565, the area for the damper is 1.532
PS: make sure you install the crank gear with the large chamfer on the ID to the inside.
PostPosted: Mon Apr 18, 2011 6:19 pm
Thanks again for your help Charlie. I should have known better.
Ken
 Post subject: You can
PostPosted: Mon Apr 18, 2011 8:40 pm
Usually heat a crank gear with a propane torch or on a scrap BBQ...with gloved hands it should slide right on pretty easy. I would use a light heat item like that and not an oxy acet set up...
Good Luck,
 Post subject: Re: You can
PostPosted: Tue Apr 19, 2011 4:15 am
Usually heat a crank gear with a propane torch or on my scrap BBQ...with gloved hands it should slide right on pretty easy. I would use a light heat item like that and not an oxy acet set up...
Good Luck,
It is that reason, I don't like muti keyed crank sprockets. Much easier to use an off-set cam bushing to adjust cam timing.
 Post subject: Yep...
PostPosted: Tue Apr 19, 2011 6:36 am
It is that reason, I don't like muti keyed crank sprockets. Much easier to use an ofset cam bushing to adjust cam timing.
I'll agree on that one, that roll master timing set with multi keyway left gouges in my crank snout once it cooled and settled in, the fit was a bit too tight for me. I'll go back to the Cloyes set up on future motors.
Users browsing this forum: Google [Bot] and 14 guests
