| power pipe DC https://slantsix.org/forum/viewtopic.php?t=44634 |
| Author: | 65CrewCabPW [ Wed Apr 20, 2011 5:58 pm ] |
| Post subject: | power pipe DC |
Has anyone run these? What do they sound like? Are they better than the iron manifold? I am converting to propane and do not want manifold heat, it's a "two-fer" or maybe 'threefer' because it removes the heat, may provide some performance increase and should sound better, too. Any experience? I emailed the seller, but haven't gotten an answer yet (few hours ago). |
| Author: | mfdu [ Wed Apr 20, 2011 6:44 pm ] |
i found the same stuff recently and got all excited. but look at it - it's 90' angles. as pointed out by a few chaps here - it aint gonna flow that good. i then found a beaut on FABO about modifying a stock cast-iron manifold by chopping out the centre heatbox section and converting to a dual-output. they guy on FABO who did it is 'waggin'. i've now got an extra exhaust manifold which i'm going to start chopping up - aiming for dual 2" running side-by-side down the LHS of the car (following stock routing) it should look ripper with my speco dual Carter BBS intake. here's a pic of waggin's work: (image courtesy of FABO - http://www.forabodiesonly.com/mopar/sho ... hp?t=36378) waggin, the guy on FABO who was responsible for the above set-up, reports the following: "the early (1966 and older) exhaust manifolds are made of cast steel (can be welded with a mig welder) 85 chevy drivers side manifolds from a monte carlo are the pieces I used to make the downpipes. I ran 2" true dual exhaust to the rear of the car I was very happy with the performance and the sound,don't know what the performance gain was but it sounded great,and i have over three years service as a daily driver on them and no problems,they are on bruces car now as I have installed a v-8 and four speed..........." |
| Author: | ceej [ Wed Apr 20, 2011 6:48 pm ] |
The power pipe has a thread lurking around here someplace. Dutra Duals, and Dual Dutra duals are the modified factory manifolds, and new casting(s) created by Doug Dutra. A quick search here will net lots of hits. I run Dual Dutra Duals on my Valiant to good effect. CJ |
| Author: | SlantSixDan [ Wed Apr 20, 2011 6:50 pm ] |
Read here and here and here. |
| Author: | 65CrewCabPW [ Wed Apr 20, 2011 7:12 pm ] |
Quote: The power pipe has a thread lurking around here someplace.
I'd love to, but that's just totally outside of my budget now.
| Author: | mfdu [ Wed Apr 20, 2011 7:45 pm ] |
yeah. for me, dutra duals price themselves out due to the cost of shipping to australia. hence the DIY approach of chopping up a stock manifold appeals . . . |
| Author: | 65CrewCabPW [ Wed Apr 20, 2011 7:56 pm ] |
Quote: yeah. for me, dutra duals price themselves out due to the cost of shipping to australia.
But I have no shop, no means of doing that. hence the DIY approach of chopping up a stock manifold appeals . . . If I had the tools, I would have simply done my own. |
| Author: | mfdu [ Wed Apr 20, 2011 8:22 pm ] |
i have no shop either. i'm taking the stock exhaust up to my local muffler guy with a 'no rush - what can you do?" type of spec. then i'll paint them up with high-temp to match stock. it'll still : a) be cheaper than a set of long-runner extractors b) look better ('stockish') with my speco dual intake c) flow better than the stock single-outlet d) be different to everybody else all good things! chris. |
