It is currently Sun Nov 22, 2026 3:53 pm
 Post subject: differential questions
PostPosted: Fri Apr 22, 2011 11:24 am
some time ago i had a problem with my 79' valiant volare, in a drag race i broke the differential, i just want to know if i can repair it or is better change it for another, and if i change it what recommend
PostPosted: Fri Apr 22, 2011 4:07 pm
Hi frutsy.
It depends on what parts are broken, and what diff you have. The F-bodies came with both 7.25 and 8.25 rear axles, if you have a 7.25, it may be better to try to find a car with a 8.25. They came in all F/M/J-bodies up to '89, and bolt right in. Getting a setup from a wagon will also probably add an extra spring, so in that case, try buying a complete axle with springs and all. If you don't know what axle you have, take a look at the rear axle identification info at dippy.org.
Olaf.
Aspenized
 Post subject: Yikes!
PostPosted: Fri Apr 22, 2011 10:04 pm
If you were in Oregon, I have a 1980 Dippy 8.25" with 2.94's in my shed I'd like to move along....
:wink:
PostPosted: Sun Apr 24, 2011 7:42 pm
i'm from mexico but i found a super bee in a junk yard, could it work?
PostPosted: Sun Apr 24, 2011 8:23 pm
¡Bienvenido aqui! What year Super Bee did you find? The early ones (in Mexico) were A-bodies, not compatible with your F-body Valiant Volaré. The first year for the F-body is 1977 (late 1976) You can also use a rear axle from a rear-drive Dart made in 1977 or later, or a rear-drive Valiant/Volaré 1977 or later, or a rear-drive LeBaron 1977 or later.
PostPosted: Sun Apr 24, 2011 8:40 pm
gracias n_n i found a 1980 super bee with the 3 shift trans
