Clutch woes and other things - 66 Belvedere
https://slantsix.org/forum/viewtopic.php?t=44737
Page 1 of 1
Author:  JoshS [ Tue Apr 26, 2011 9:27 am ]
Post subject:  Clutch woes and other things - 66 Belvedere
Hi all,
So glad I found this forum. I've been love with the slant six since we owned a 69 Dart as our family car growing up (then a 79 Aspen wagon, then my very own 75 Dart in my first job after college).
Last week I fell in love with and bought a 66 Plymouth Belvedere II. Navy blue, four-door, slant, three-on-the-tree. 46,000 miles, and in mint condition. People gasp when they see the condition of the interior. Francine is a beauty.
But, she's been laid up in the shop for a week. I knew she needed a new clutch, but didn't know getting it would be so hard. According to my mechanic, there's an industry-wide mislabeling of the clutch kit used for this car. The labeling claims that two different-sized plates (or flywheels?) are interchangeable in this car, but they're not. The thing wouldn't fit back together. My garage finally found the proper part from a shop in California, which has to ship it here to the East Coast. Has anyone else experienced this?
I have a question for three-speed owners: The car is a joy to cruise down the highway with, but being used to a five-speed, the rpms at 65 seem alarming to me in third gear. I don't have a tachometer, but I can hear the engine. Do I need to be worried about damaging the engine with highway driving? I mean, I know they built and sold the car, obviously assuming it would get some highway driving, but it just seems intuitive that such high rpms would contribute to faster engine wear.
Thanks for any thoughts.
Author:  Doc [ Tue Apr 26, 2011 9:35 am ]
Have the mechanic check the rear end gear ratio, while the car is at the shop.
A higher rear gear ratio may-be the solution.
Author:  JoshS [ Tue Apr 26, 2011 10:18 am ]
Will do, Doc. But should I assume that high rpms *are* actually a problem, considering the car is all original and was sold with the assumption it would be driven on the highways sometimes?
Author:  Reed [ Tue Apr 26, 2011 10:51 am ]
I would install a tach and see exactly what the "high" RPMs are.
Author:  SlantSixDan [ Tue Apr 26, 2011 12:03 pm ]
Post subject:  Re: Clutch woes and other things - 66 Belvedere
They're not and never have been, and just ducking onto rockauto.com I don't see any such a labelling error. The 9¼" clutch is listed separately from the 10" clutch. The former was standard equipment, the latter was the heavy-duty option. A 10" clutch can be retrofitted to a car with the smaller clutch, but you have to have the special bolts.
With such low miles, your '66 may not have had TSB number D66-32 applied, concerning the installation of a clutch fork return spring so the clutch pedal always returns all the way up, every time. Check for the presence of such a spring; install one if none is present.
Your car hasn't got an overdrive top gear. It probably has a 3.23:1 rear axle ratio, so yeah, you're going to hear the engine on the highway. See here for how to check the rear axle ratio.
Tune-up parts and technique suggestions in this thread. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. And you'll want to get the three books described in this thread.
Author:  JoshS [ Tue Apr 26, 2011 1:36 pm ]
Thanks Dan! I love how much I'm learning here. My mechanic is going to check the rear axle ratio.
I know the car does not have an overdrive gear. But I'm still wondering if I *need* to be worried about those high rpms (once I can get a tach on there I'll know what they are). I mean, is it standard advice to say, "Oh, you've got a three-speed, so don't drive over 50 mph," or is it "That's just how they were built, and you'll be fine at highway speeds, just won't get as good gas mileage."?
I'd really like some expert opinions on that.
Author:  SlantSixDan [ Tue Apr 26, 2011 1:56 pm ]
No, of course not. When that car was built, there was no national speed limit, and many of the Western states had unlimited highway speeds.
Yes.
Author:  Doc [ Tue Apr 26, 2011 2:23 pm ]
And remember... there were a number of "optional" gear ratios available for the vehicle so the customer could select a different one, based on their intended use of the vehicle.
For me, I tend to change gear ratios in my vehicles as my driving needs / situation change. (most of my vehicles have the 8 3/4 "drop-out" rear end so ratio changes are somewhat easy)
I choose a gear ratio so I am in the 2800 to 3000 RPM "sweat spot", most of the time.
Author:  JoshS [ Tue Apr 26, 2011 4:43 pm ]
Thanks again guys, especially for patience with dumb questions. I do search the archives first to try to learn on my own, I promise. :D
Author:  DusterIdiot [ Tue Apr 26, 2011 6:24 pm ]
Post subject:  Lol...
Unless the dipstick mechanic thought it should have the 11" clutch for the cop car taxi cab option (or just had a brainfart and thought that the standard LA clutch-10 1/2" was the same for us...)
:roll:
I've heard way to many of these, and unfortunately been to late to help the customer before the money left their wallet....
Author:  SlantSixDan [ Tue Apr 26, 2011 7:27 pm ]
Post subject:  Re: Lol...
Yup, agreed. Just in lighting-related matters alone, I clean up many expensive messes that could've been avoided altogether by asking first, before buying parts.
