It is currently Sat Oct 24, 2026 4:36 pm
 Post subject: dyno results
PostPosted: Sun Nov 24, 2002 6:32 am
The engine is stock bottom end, ..060 over bore,1.74 intake valves,1.44 exhaust, light porting and a comp cam. Its turbo is a t3 and it is intercooled.
208 hp and 313 tq at the wheels. 8 psi
The pics are in the drag strip sect
Andrew Wagner
:twisted:
I will not live without boost again. I just like the sound of the blowoff valve.
PostPosted: Sun Nov 24, 2002 11:36 am
Those are some pretty good numbers Andrew! :D Did you ever get it back out to the dragstrip yet? :shock:
PostPosted: Sun Nov 24, 2002 4:24 pm
Hey Andrew that's great. At what RPM were these numbers taken? Anyone have any idea what that would translate to in terms of engine HP? I believe Andrew has a standard transmission.
PostPosted: Sun Nov 24, 2002 5:09 pm
I believe standard loss is figured at around 18%. That would put Andrew right around 250 or so at the crank. :D :shock:
 Post subject: dyno
PostPosted: Sun Nov 24, 2002 10:17 pm
the peak tq was at 3000 rpm and the peak hp was at 4000 rpm. I can't get to the drag strip until the end of winter.
Andrew wagner
:P
PostPosted: Wed Nov 27, 2002 11:06 am
Great results andrew ! What kind of head gasket do you use ?
Christian
Users browsing this forum: Rick Covalt and 11 guests
