| need help https://slantsix.org/forum/viewtopic.php?t=44762 |
| Author: | Turbo Toad [ Wed Apr 27, 2011 5:49 pm ] |
| Post subject: | need help |
Does anybody no whatever size crank damper bolt is need on a 73 /6 Neither of the two motors that I got at home have them |
| Author: | SlantSixDan [ Wed Apr 27, 2011 9:59 pm ] |
The bolt's not "missing". Most slant-6 engines came without them. The damper is an interference (press-on) fit onto the crank snout. If you want to install a bolt for some reason (or you need one to install the damper), it's a ¾"-16 × 2½" bolt with appropriate washer. |
