| unruly window lift arm in my 73 dart https://slantsix.org/forum/viewtopic.php?t=44765 |
| Author: | easy803 [ Wed Apr 27, 2011 7:00 pm ] |
| Post subject: | unruly window lift arm in my 73 dart |
The window lift works but it wants to pop out from under the glass... towards the inside leaving the glass hanging or slamming down....how do I subdue this rebellious arm! |
| Author: | THOR [ Thu Apr 28, 2011 8:28 am ] |
Sounds like its bound up, broken, or seriously in need of lubrication. Pull the regulator out and clean it up, see if it is still hard to roll up or down without the window. Its possible that your window is trying to come out of the track. ~RDE~ |
| Author: | easy803 [ Thu Apr 28, 2011 10:51 am ] |
It rolls smooth I took the panel off its all good it just kinda pops out from under the glass |
| Author: | THOR [ Thu Apr 28, 2011 11:47 am ] |
4 door or 2 door? You say its popping inward towards the panel (you) right? What shape are the inserts on the window in? |
| Author: | easy803 [ Thu Apr 28, 2011 12:34 pm ] |
4 door and super thrashed... yeah towards the inside |
| Author: | easy803 [ Sat May 21, 2011 8:30 am ] |
Welp... nobody mentioned the part I was missing that BOLTS to the window... found it under my seat in my car... solved it |
