| New clutch, but can't get into 1st or reverse - grinding https://slantsix.org/forum/viewtopic.php?t=44781 |
| Author: | JoshS [ Fri Apr 29, 2011 2:40 pm ] |
| Post subject: | New clutch, but can't get into 1st or reverse - grinding |
Hi all, my mechanic and I are stumped and frustrated, and would appreciate any tips you might have. I have a 66 Belvedere slant with three-on-the tree. Last week they replaced the clutch, but it was the wrong size, so we had to wait to get the 9 and 1/4. That's now in, but you can't get the car into 1st or reverse. It grinds horribly. Moving from neutral to 2nd then down to first does not help. Double-clutching does not help. Does anyone know what might be wrong? The shop has already tried several different grades of transmission fluid, and it makes no difference. Thanks much for any help. It's frustrating having just bought her, and unable to drive for almost two weeks. |
| Author: | 1974duster kev [ Fri Apr 29, 2011 2:51 pm ] |
Can you get it in gear when the car is off? If so i've been told your clutch disc could be hanging up if it grinds trying to go in gear or maybe something going on inside the trans have you guys had it apart? Is the clutch adjusted enough so that the you can spin the tires with it in gear with the clutch pedal to the floor ( car is off while doing this on a lift or jack) Kev |
| Author: | Joshie225 [ Fri Apr 29, 2011 4:37 pm ] |
If the pilot bearing was not replaced and the input shaft droops the clutch will drag. If the pilot bearing was replaced and it seized on the input shaft the clutch will drag. Pull the inspection cover and have someone knowledgeable observe the clutch when the pedal is depressed. |
| Author: | Fopar [ Fri Apr 29, 2011 5:26 pm ] |
Might sound silly, was the clutch plate put in correctly. It will go together backwards but will not disengage, as the center is against the flywheel. Richard |
| Author: | 4speed [ Fri Apr 29, 2011 5:32 pm ] |
Check to make sure the clutch plate is not pinched by the pressure plate were its bolted to the fly wheel. |
| Author: | BUCKET 636 [ Mon May 09, 2011 8:16 pm ] |
I have just installed a new clutch and reconditioned gearbox into my 1965 Chrysler Valiant. I was having this exact same problem. To start with i adjusted the clutch pedal so it engaged about 1 1/2 inches from the floor. I then had to adjust the linkages even though it was the same style gearbox that was originally in the car. Make sure the nuts holding the selector arms on your gearbox are tight as well,if these are loose there may be enough play to cause the selector arms to move making it hard to get gears. I don't know if this has any relevance to your car. |
| Author: | raycycled [ Tue May 10, 2011 12:05 am ] |
| Post subject: | clutch shudder |
In our 63 valiant with a 3 on the tree, I am getting a shudder when taking off, clutch doesn't slip just this rumble as you start from standing, doesn't do it in 2nd or 3rd ,took off the cover plate and had a fiddle... looks fine and clutch seems to be adjusted properly with a little free float so the throw out bearing isn't riding, any suggestions, RAY |
| Author: | Doc [ Tue May 10, 2011 8:35 am ] |
The 'shudder' could be the clutch or from the Ball & Trunion front U-joint, those can cause start-off vibration when the outer housing gets worn. Start-off clutch chatter can have a number of different causes but most often, it's the flywheel surface not being clean, smooth & flat. (the flywheel needs to be resurfaced) Another cause, the clutch disk's center or hub is "bent", in relation to the outer friction material. This happens when the transmission's input shaft gets's partially inserted into the disc hub, then the trans is allowed to 'hang down', putting angled force into the disc's hub. (use a transmission jack to install the gearbox) DD |
| Author: | 1974duster kev [ Tue May 10, 2011 5:20 pm ] |
Could shutter from no pilot bearing, or being worn Kev |
| Author: | raycycled [ Tue May 10, 2011 7:45 pm ] |
So basically i'M STUFFED and have to drop the gear box? RAY |
| Author: | 4speed [ Tue May 10, 2011 8:19 pm ] |
Ray-have you checked your motor mounts/tranny mount? |
| Author: | raycycled [ Tue May 10, 2011 10:20 pm ] |
No not yet , bloody headlights went out on me last night working on that today, RAY |
