It is currently Sun Nov 22, 2026 2:13 pm
PostPosted: Sat Jul 20, 2013 8:01 pm
need to install a balancer/need to buy a bolt
wondering what is that size ?
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Jul 20, 2013 8:06 pm
Site Admin
3/4 - 16 UNF
PostPosted: Sat Jul 20, 2013 8:17 pm
thank u sir>
slant six's RULE!
PostPosted: Sun Jul 21, 2013 12:49 pm
Same as V8.
Olaf
Aspenized
PostPosted: Sun Jul 21, 2013 1:41 pm
I put one from a bb Chrylser 400 in mine.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Mon Jul 22, 2013 8:29 am
how's that working out ?
slant six's RULE!
PostPosted: Mon Jul 22, 2013 8:33 am
I can not find that bolt local
any thoughts where I could purchase?
slant six's RULE!
 Post subject: Junkyard or...
PostPosted: Mon Jul 22, 2013 9:55 am
If you can't find a small or big block Mopar in a local junkyard, and you don't have a local fastener place, you'll be looking at McMaster-Carr or another online fastener place.
PostPosted: Mon Jul 22, 2013 4:23 pm
The crankshaft vibration dampener bolt is 3/4"-16 UNF, 2.3 inches long, with a 1.5 inches minimum length threaded area.
You will also need a thick washer, the washer is 1-15/16" x 1/4".
summitracing.com: part number DCC-5249557AB
Mopar Performance #P5249557AB - Mopar Performance Harmonic Balancer Bolts 3/4-16 x 2.250 inch (underhead)
Olaf
Aspenized
PostPosted: Mon Jul 22, 2013 4:44 pm
I got mine at the local Hardware store. "Do it best Hardware"
PostPosted: Mon Jul 22, 2013 6:00 pm
Car Model: 1964 Valiant V200
edit: I see Olaf has the same info.
 Post subject: Fyi...
PostPosted: Mon Jul 22, 2013 6:13 pm
This will not come up with the "AB"...
Summit Lists it as DCC-5249557 at $9.97
FYI.
PostPosted: Mon Jul 22, 2013 7:08 pm
Motor isn't together but it threaded into the crank no problem.
PostPosted: Tue Jul 23, 2013 7:47 pm
Thank you DI, archive is updated!
Olaf
Aspenized
 Post subject: Re: Fyi...
PostPosted: Sat Aug 03, 2013 2:54 pm
FYI.
just ordered one on ebay from summit
slant six's RULE!
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 7 guests
