Engine year ID
https://slantsix.org/forum/viewtopic.php?t=44792
Author:  AHamilton [ Sat Apr 30, 2011 5:13 pm ]
Post subject:  Engine year ID
I, at first, believed this to be the orig motor. The guy selling it to me seemed honest, told me so. Well after reading more about the /6, I realized it has 5 freeze plugs. It can't be a 63 motor, it has only 3 freeze plugs...if my memory serves me correctly. Can you all help me figure out approx year and if this would be a solid lifter or hyd lifter. The gasket at the local shop is out of stock and is being ordered as I type. the block number under the intake/exh manifolds is 2806830-8. Thanks guys.
Andy[/img]
Author:  61 V200 [ Sat Apr 30, 2011 6:00 pm ]
Read This article for block ID.
Head has a boss stamped just behind the alternator for ID. Likely will have to clean it to see the numbers.
Author:  Chuck [ Sun May 01, 2011 10:22 am ]
When you find the number, go here under VIN Decoding to decode it.
