It is currently Sun Nov 22, 2026 10:08 pm
 Post subject: Retorque of Pinion nut
PostPosted: Tue May 03, 2011 2:34 pm
What is the proper way to reinstall the pinion nut on a 489 case 8 3/4? Ryan ordered a new drive shaft that should be here shortly. He went with a larger u-joint / yoke so we will need to swap it out. Does it get torqued to the same specs as initial setup or something different?
Rick Covalt
PostPosted: Tue May 03, 2011 2:41 pm
Mark the nut and pinion shaft and count the turns when you take it off. Replace the seal and yoke, and tighten the nut the same number of turns and line up your mark. Don't try retourquing, you'll just crush the sleeve some more. :D
PostPosted: Tue May 03, 2011 4:27 pm
If you have a nice inch pound torque wrench, check the rotation force prior to removing the nut and yoke.
R & R the yoke as discribed above and put the nut back to the same position, then re-check the rotation force.
If the force is significantly less and / or you feel some side play in the pinion bearings, tighten the nut a bit more... to get back to the original rotation force reading.
Users browsing this forum: No registered users and 14 guests
