| 66 Belv transmission still whacked - 1st and rev. grind https://slantsix.org/forum/viewtopic.php?t=44811 |
Page 1 of 2 |
| Author: | JoshS [ Mon May 02, 2011 9:51 am ] |
| Post subject: | 66 Belv transmission still whacked - 1st and rev. grind |
Hi all, Thanks for the tips on dealing with my 66 Plymouth, which grinds so hard it won't go into 1st and reverse. I printed them out and left them at the mechanic's. He thought he'd solved with a different grade of fluid, but it's no better. I have to think the clutch is not fully disengaging. Why? Well I got into the car after it had been sitting, started it, then tried first and reverse. Hard, hard grinding, and couldn't get it into gear. How is the engine transmitting force to spin up the transmission if I've got the clutch down, and the car hasn't been moving, and was just started cold? Does this make sense? |
| Author: | Doc [ Mon May 02, 2011 10:13 am ] |
Yes... it is more likely to be a sticky clutch or mis-adjusted clutch peddle linkage than a trans problem. DD |
| Author: | Joshie225 [ Mon May 02, 2011 10:15 am ] |
it's obvious the clutch is dragging for reasons we've already gone over in the previous thread. Put the car into gear and then start it. Does it turn over normally? I'm wondering just how badly the clutch is dragging. |
| Author: | JoshS [ Mon May 02, 2011 10:32 am ] |
Josh Skinner - I haven't been able to try putting the car in gear and then starting today, but the other day I did so and it was fine. Also, my mech. did the same thing today, because in order to start from a stop in first, he had to shut it off, shift into first, and then start it. Since it's at the shop now, and I'm at work, I can't hop in it. It's so beastly frustrating - a clutch shouldn't be this hard:) |
| Author: | JoshS [ Mon May 02, 2011 10:36 am ] |
Also, the guys at the shop are really balking at the idea that they might have put the clutch disc in backward, and I'm wondering if I should really push them to swallow their pride and check anyway. |
| Author: | wjajr [ Mon May 02, 2011 11:05 am ] |
This simple, if a shop installed the clutch, and you paid for it, and the clutch is not functioning correctly it is their responsibility to correct the problem. They need to eat the labor, if additional parts are needed that would be on your dime. Clutch work on a 45 year old car ain’t rocket science. Why would they return a non running car to the customer? Stopping or killing engine to get into gear, than starting with transmission in gear... You will be shopping for a new starter if that gig keeps up. |
| Author: | JoshS [ Mon May 02, 2011 12:53 pm ] |
Oh, just to be clear, they didn't return it to me - we both agreed I should try and drive it to see what it was doing (and half hoping it would work itself out). Just went up the block and back, then left it with them. Quote: This simple, if a shop installed the clutch, and you paid for it, and the clutch is not functioning correctly it is their responsibility to correct the problem.
| Author: | Fopar [ Mon May 02, 2011 1:34 pm ] |
Quote: Also, the guys at the shop are really balking at the idea that they might have put the clutch disc in backward, and I'm wondering if I should really push them to swallow their pride and check anyway.
They should have checked it out before even asking you to try it. This kind of shop is what gives the auto repair business a big black eye!!Richard |
| Author: | wjajr [ Mon May 02, 2011 2:37 pm ] |
In Maine we have a special way to repair engines and transmissions called Tripod Power, not to be confused with razor blade fixing pyramid power. All one has to do is pull bad engine and transmission from car, let them dangle by chain from a tripod fashioned from three Cedar poles, Cedar won’t rot too fast, for a few years outside. Then reinstall it in the car, and it will work flawlessly… This has worked for Downeasters for years. Was this transmission to heal thy self after you laid hands on it? Once those Bozos fix it, run from that shop. |
| Author: | Mroldfart2u [ Mon May 02, 2011 2:47 pm ] |
If it was it would not dis-engage @ anytime, so its not that... I would surmise that its a faulty Pressure Plate, if it isn't in the clutch adjustment itself... As one poster up ^^^^^ there said, a 40 year old standard shift car is NOT rocket science. |
| Author: | Doc [ Mon May 02, 2011 2:57 pm ] |
Once upon a time... we had a car with a clutch that would not dis-engage well. Upon checking, it was out of adjustment so we readjusted and it worked OK for a few uses and then was back to little dis-engagement. We went to pull-out the clutch but upon removing the "bellcrank" (some call it the "Z-bar") we saw that the welded arm was cracked and breaking-off the tube. We knocked the arm back into position, rewelded it with a reinforcement "gussit" and re-installed it. The clutch worked fine after that. DD |
| Author: | sandy in BC [ Mon May 02, 2011 3:40 pm ] |
It would take 20 mins on the hoist to pull the trans and check the clutch. I bet the disc is in backwards. |
| Author: | THOR [ Mon May 02, 2011 5:20 pm ] |
I am voting for mis-adjustment, and/or z-bar failure. Its not like they looked all that strong to start with... ~RDE~ |
| Author: | 4speed [ Mon May 02, 2011 5:55 pm ] |
I had forgotten about the "Z" bar-thats a good place to look. Some thing is spinning the input shaft to the tranny. Clutch is dragging or input shaft is binding on the crank shaft (pilot bushing). With the car on a lift-take off the inspection cover on the bell housing. Have someone push on the clutch pedal from inside the car. If the PEDAL has the right free play but the THROW out bearing does not move much and the clutch does not fully release then there is a problem between the pedal and the throw out bearing like a bad "Z" bar or pivot. With the clutch pedal pushed to the floor check the clearance of the clutch its self against the flywheel-all the way around/turn the engine by hand. I had a new pressure plate go bad were one of the three "finger" cracked at the pivot inside the pressure plate and did not fully release the clutch. |
| Author: | JoshS [ Tue May 03, 2011 9:39 pm ] |
| Post subject: | She's home |
Got the car back today. Mechanic said the new clutch plate just wasn't right - too many springs causing it to push with too much pressure. He put the old one back on, and ordered a new one from Year One Auto that should be correct. Will put it in free when it gets here, I just have to pay for the part. She's totally driveable. Still getting a little tranny spin from the engine with the clutch down, but minor. All I have to do at a dead stop to prevent grinding is shift into second or third to take advantage of the syncro, then down into 1st. Works seamlessly. I really appreciate all the advice here, and I've compiled it all for my shop for their troubleshooting needs. My camera's crappy and today was hazy, but here are some shots of the car: http://img23.imageshack.us/g/francinewheel.jpg/ Bonus - I finally looked under the carb cover that said "Super Six" today and lo and behold, someone had indeed swapped out the original 1bbl carb for the 2bbl Super Six. Whoo-hoo! Now I know why such a big car has such good acceleration with a slant six. It's a noticeable difference from my 75 Dart, which was a bit smaller and had less pickup. |
| Page 1 of 2 | All times are UTC-08:00 |
